Fight you for the corner blondie!
Business is business, if you pick some up on the corner, then good for you. :P
Shell got the car back for real??? I can feel a Cruise coming on. :woot:
Spotted this today at work. It demanded *Giggles*.
https://www.sau.com.au/forums/topic/30059-spotted/page/859/#findComment-6949330
Yes, I was thinking in 3 weeks. I'm busy for the next two and it gives people plenty of notice.
We'll work on that then. :)
Maybe some extra cruisey fun in the meantime...
CLAM FLANGE!!!! *giggles* :rofl:
https://www.sau.com.au/forums/topic/30059-spotted/page/859/#findComment-6949368
Yeah I also spotted the shitbox skyline yesterday arvo at the lights from Belconnen way onto GDE - I pulled up next to it. I would've waved, but firstly it was FJ's missus driving, and secondly I was on the bike lol
https://www.sau.com.au/forums/topic/30059-spotted/page/859/#findComment-6952757
Yeps, tokyo taxi going a little lower with new shoes :)
got new highflow turbs on yesterday (old OP6 had a seizure)
Dr Rob and nurse Jeremy watched it die with me last weekend....
Thought it was yours but only saw the tail. White 33 there also with drift toy hanging of the tow hook.
Your car looks awesome Tom - Swaps this arvo ??
https://www.sau.com.au/forums/topic/30059-spotted/page/859/#findComment-6952969
Sup. My contribution were duly noted. "Is the Actuator on backwards?" LOLOLOL I know my cars.
Edited by RosieR34
https://www.sau.com.au/forums/topic/30059-spotted/page/859/#findComment-6953001
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
