  • 3 weeks later...
12 hours ago, Anfanee said:
you can get it from like two servos in Canberra lol
Works for me.  One is 5 min from my house the other is on my way to/from work.
Also, spotted a white R35 on Parkway/GDE last night around 6:30. Was on my way back from a formal run.
  • Like 1
  • 8 months later...
  • 2 months later...
  • 2 years later...
D E A D.......................I drove from my place to Fyshwick via Tuggeranong Parkway and Hindmarsh etc and didn't see another Skyline of any description.  What happened to all the Canberra trend setters?
I was loitering in your street...didn't see a thing.....lmao
Yeah, look I know that there are still a dedicated few, but we are all getting thin on the ground.  I drove 200km to Fyshwick, picked up my mailbox, then 200km home.  Plus sliced through a couple of major arterials etc and didn't see anyone.  Used to be that I would see 4-5 Skylines or more...didn't even see an R31 this time round.
  • 4 weeks later...
  • 2 months later...
