  • Replies 259
4yrs in this club and ive never seen your car. Do you still even have one? :P
Time to pass on the rb20 minister position to me :)
Yeh its around somewhere. It did do Dutton in 2007 and track days up to end of 2007. I was OS most of 2008 and all of 2009 and i live around the corner from committee meetings so just walk:)
not good enough, everyone selling up their r32's and no one is left :P
Entry emailed and paid. Put me down on the list! RB20 powar :)
4yrs in this club and ive never seen your car. Do you still even have one? :down:
Time to pass on the rb20 minister position to me :P
You will have to prove you have what it takes. This Deca might be your chance!
What's stopping you? Out of the country?
NOTICE RE LICENCES
CAMS - Click Here and Download the L2S SPEED LICENCE
$100 per year & you must be able to prove that you are also a current financial member of a CAMS affiliated club (ie SAU Victoria)
AASA - Click Here and Download the CLUB RACING LICENCE
$50/year
Make sure you all check that your license and club membership (if you are using a CAMS Licence) are up to date.
We cannot handle renewals of CAMS or AASA license. You will need to sort it out with them before the event if it's close to expiring.
If you are new and do not yet have a licence, I can process it for you on the morning of the event, but make sure you come with the correct form already filled in and the correct $$.
Hope this helps you all. If anyone has further questions about licences, PM me :P
deca is the best, i haven't told my sister yet i'm going to shep not her wedding lmao
forms emailed and money sent via net banking, damm payment delay, anyhow x2 entry's have been submitted for Myself, David Talbot, and Vincent Ritchie, and we will be both driving my silvia so please put us in the same group Ryan, but obviously a few cars apart.
thanks, i'll get in touch with other people asap regarding more entry's.
see you all there !
Dedication!
It might help the organisers process your entry faster if people include in their fax a receipt of the internet bank transfer...that way we can see some proof you've paid (even though we still need to see payment in the SAU Vic bank account before your entry is completely accepted).
i see that everyone is mighty pumped about DECA. so much more discussion about this than the hillclimb next weekend.
anyone care to go into a little more detail about what goes on at one of these days?
cant go to the hillclimb cause i have paintball :D
I haven't sold it...i am actually picking it up tomorrow from just having had some work done to it. I wanted to burn the R32 not that long ago but cars are a love hate thing:)
oh yeh thats when you need to cast them aside and drive something else, otherwise you end up selling and regretting it later. i seriously forgot about 1 car once LMAO but you get that. it was sitting somewhere for a year, that's my excuse. :(
7 Spots left guys.
And just to let you all know, we will be running the day in the old format for those of you who have been to a few decas. This is a little bit more passenger friendly so get your friends/girl/boyfriends up there!
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
