ive had my 33 for 7 years now
it's done 23,000 each year since i got it
broken radiator
coilpacks died
alternator replaced
diff is grumpy
usual wear and tear - clutches, tyres
37% more power than stock and held up pretty well considering
hehe. I'm in a similar situation but not. I've had my Pulsar for 7 years. Done a bit less than 10,000kms per year as it spends most of it's life off the road.
I've broken well...EVERYTHING.
Should be making 200-210fwkw with the manual behind it. Bit of an increase over the 50fwkw it had stock.
Well done :domokun: That's impressive!
What's it like having so much power at the front wheels in such a small car?
What brakes have you got on there? Stock? Coz if so then I know what you mean by 'stopping is the hard part' ;)
Sort of stock. Front and rear calipers and disks upgraded to SSS items (single piston, but a fair amount bigger.) The car came with a drum brake rear end and piddly little front calipers stock. It could do with better brakes but they still pull it up okay (even from 200kmp/h+) and I have other priorities.
Poles help?
Arse :laugh:
Poles stop cars very quickly, much more effective than 8-Pots :D
web development, I'm guessing its the same thing Pat's goin for but a more junior role?
nah mines for a graduate engineering position in a flexible plastic packaging manufacturing company. (beer wrapping on 6packs and cadbury wrappers etc)
The tests were pretty lol, the maths questions were overwhelming haha
Ah well, will see what I got next week and if move to 3rd stage which is another interview zzzz
i wouldnt stress too much re: getting the answers correct
i mean obviously there is merit testing your technical and maths etc for general assesment
but sometimes they give you bullshit ones where there is no correct answer
they do this to see your lateral thinking and problem solving tactics, even though there is no correct answer
ive done this a few times when interviewing techs, give them a problem and provide multiple choice where all the answers are wrong
the guy who stands one is the one who scribbles near it trying to debunk the correct answer and goes on to discuss the possible causes etc, the ones you dont want just circle an answer or leave it blank
lol at men in black.
Yeah, will see how it goes.
On another note, my dad blew up his mitsubishi express van engine.
Does anyone know where to get a replacement engine or another van? I see hundreds of them on the roads yet there is nothing on ebay, carsales, carpoint, autotrader.
I guess people selling them are old tradies and dont bother advertising online.. Where would be the best place to search for these vans? Probably notice boards at pubs or something haha
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
