ye, well I'm not about to go and buy 2 more TE37s just for the sake of offset, though I think I'm going to have a problem when my ATTESSA is working again with having staggered fitment anyway blah
You should be fine!
why not? once you have jap rims, then secondhand jap rims are a freeforall... just sell 'em for the same price as the next set you are buying
if you're using spacers, make sure you get the washers on them to stop them moving around and they won't mess your wheel balance up. if possible get ones with hub bolts, they're "safer" than just slip on's and don't move around at all, but you'd need a 15mm+ spacer for that, which might be too much.
but yeah, nothing beats choosing the right wheels with the right offset.
too much effort haha, yeah I'd never use slip ons, an R33 here had a wheel fall off due to having fark all thread and having the wheel nuts come off LOLZ.
Here's a pic to show fitment as it is currently :
Rear looks decent and could go more low!
your talking about slip on spaces hubcentrics bolt on to ur existing hub and give u 5 new threads so you do not lose any thread and if his wheels fell off with hubcentrics then a retard tightened them.
deff need to sort out the front and slam that tractor. john deere reprezent!
yeah, rear is fine. front needs a little more out... 15mm to 20mm? then roll the lip on the guards and drop it by just under an inch, should leave minimal gap, you don't have to run stretch tyres, shouldn't have scrapage on lock or over bumps... but it'll look tough. probably will get defected for height though cos the bottom lip of the front spoiler will drop under 10cm.
alternatively if you don't give a fuck, then do this:
18x9.5+15 front
18x10+20 rear
near perfect fitment for R32 narrowbodies. maximum wheel width, no fouling on suspension, and with a roll, no scraping.
alternatively if you don't give a f**k, then do this:
18x9.5+15 front
18x10+20 rear
thats AWESOME!
wheel sizes noted :stupid:
is that yours?
lol nah, mine's 6 different colours and runs stock GTR wheels atm... one day I'll get off my arse, fix the ABS system that's causing the front passenger side brake to permanently clamp on, and paint n panel it and throw on some wheels.
or I could sell it as is and drive the camaro when it gets here.
seriously cbf with the skyline atm.
18x9.5+15 front
18x10+20 rear
lol what size tyres are those?
Im running 17x9 +30 with 255/40's and no chance that will tuck under the guards with -0.5deg camber & rolled lip
hehe that does look sex, I like my ride height lol, no scraping on speedhumps or police attention for me! I actually like it that height, no scraping on speedhumps or police attention for me, and if I park too close to teh kerb, there's about 2mm of clearance to the front spoiler lol.
I would have thought that if I get the fronts to stick out further, that I'd have trouble with it fouling on full lock etc ^_~
As it is, the exhaust just clears 10cm, don't really have much fine adjustment re height, the coilovers are only circlip adjustable! More concerned with handling tbqh.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
