ye, well I'm not about to go and buy 2 more TE37s just for the sake of offset, though I think I'm going to have a problem when my ATTESSA is working again with having staggered fitment anyway blah
You should be fine!
why not? once you have jap rims, then secondhand jap rims are a freeforall... just sell 'em for the same price as the next set you are buying
if you're using spacers, make sure you get the washers on them to stop them moving around and they won't mess your wheel balance up. if possible get ones with hub bolts, they're "safer" than just slip on's and don't move around at all, but you'd need a 15mm+ spacer for that, which might be too much.
but yeah, nothing beats choosing the right wheels with the right offset.
too much effort haha, yeah I'd never use slip ons, an R33 here had a wheel fall off due to having fark all thread and having the wheel nuts come off LOLZ.
Here's a pic to show fitment as it is currently :
Rear looks decent and could go more low!
your talking about slip on spaces hubcentrics bolt on to ur existing hub and give u 5 new threads so you do not lose any thread and if his wheels fell off with hubcentrics then a retard tightened them.
deff need to sort out the front and slam that tractor. john deere reprezent!
yeah, rear is fine. front needs a little more out... 15mm to 20mm? then roll the lip on the guards and drop it by just under an inch, should leave minimal gap, you don't have to run stretch tyres, shouldn't have scrapage on lock or over bumps... but it'll look tough. probably will get defected for height though cos the bottom lip of the front spoiler will drop under 10cm.
alternatively if you don't give a fuck, then do this:
18x9.5+15 front
18x10+20 rear
near perfect fitment for R32 narrowbodies. maximum wheel width, no fouling on suspension, and with a roll, no scraping.
alternatively if you don't give a f**k, then do this:
18x9.5+15 front
18x10+20 rear
thats AWESOME!
wheel sizes noted :stupid:
is that yours?
lol nah, mine's 6 different colours and runs stock GTR wheels atm... one day I'll get off my arse, fix the ABS system that's causing the front passenger side brake to permanently clamp on, and paint n panel it and throw on some wheels.
or I could sell it as is and drive the camaro when it gets here.
seriously cbf with the skyline atm.
18x9.5+15 front
18x10+20 rear
lol what size tyres are those?
Im running 17x9 +30 with 255/40's and no chance that will tuck under the guards with -0.5deg camber & rolled lip
hehe that does look sex, I like my ride height lol, no scraping on speedhumps or police attention for me! I actually like it that height, no scraping on speedhumps or police attention for me, and if I park too close to teh kerb, there's about 2mm of clearance to the front spoiler lol.
I would have thought that if I get the fronts to stick out further, that I'd have trouble with it fouling on full lock etc ^_~
As it is, the exhaust just clears 10cm, don't really have much fine adjustment re height, the coilovers are only circlip adjustable! More concerned with handling tbqh.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
