i rkn u might need spacers 18x9.5 +20 isnt very aggressive fitment obviously depends what you want but im running 18x9.5 +15 on the front of my 33 but it does have wide front guards but 34s have wider guards then a 33 anyway..
if that makes sense haha
well i was thinking seeing as this is my daily i cant go too crazy but when i had these wheels on the car which is 19X9.5 +20 with very very very thin profile rubber it was pretty aggressive for me
on my 18's i will have 30 profile rubber with not as much stretch and the front has been lowered a little since so might work. rears i may need spacers.
What i plan on putting on the evo 18x9.5 +20 will be flush as most ppl dont run more than a 9 +30
Nothing looks sicker and fills out the guards better on an EVO7 - X then a set of 19" Advan RS's
These are only 18s but you get the idea...
The 19s just look awesome on it... fell in love with them ever since i saw a gun grey EVO 8 on JSpec a long while back with Gun Grey 19s on it, dumped... was instant jizz. On yellow, like Dezz said, Black... or gun grey.
There are TE37's yeah?
No sticker, just making sure that's all.
That would looks so nice on a EVO.
would need to go black on the yellow imo
+1
Yellow car / Black wheels.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
