is he on the elgrand forum? the aus one... cause someone was on there asking about them as they were going to order them.
we got them on ours with the electronic damper controller and theyre awesome... ive had to raise it up a bit though, especially in the rear because there was no clearance between the rear axle and the bump stops so it was bottoming out on every pot hole and slight bump.
want to get some new wheels for it soon... white with polished lip.
Yeah I think so man, my friends name is Rowan.
+1 for the suspension you got.
That's so good as you can raise / lower the car anytime.
What wheels you getting?
Is that a Supra with a Ford front and rear? :);):D
Looks like its a shortened ford - based on the pics on the photo board leaning on it
Looks like a Fucked up piece of shit!
:D
Hmmmm, now you put it that way perhaps he's onto something.
Empty roads, great drugs and plenty of dirty monkey sex unobstructured by morals.
VOTE ONE BOB BROWN!!!
lol yeah let's heed Bob Brown's preachings.. cull the population, distribute free drugs, regress towards primitive creatures etc
Yeah, when I get off my P's. I'm tossing up between an MR2 turbo, R32 GTS-T or GTR.
Would love to sell the Supra now but being sensible and holding on... 10 months left now.
I see, finally thinking ahead properly :)
Sell the 300ZX and Supra and work out how much you will have and go from there.
man keep ur car its the secks.
Haha!!
Yeah for sure Alex!
Not selling it.
Just saw the F1 car and supertaxigoing around Albert Park then...
I :ermm: at the V8 super car add when they used the singer Pink to promote it.
So AUS needs a mega lesbian chick to advertise for V8 super cars..?
Must by say something about V8 super cars...
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
