Tell Blipman that :)
I do, on a regular basis. That's why he went and bought an R33 ;) Anything's an upgrade I suppose. Then he got a 180sx and then a Smellsior. Also if you see Ben, tell him I said hi, haven't seen him in over a year now.
fugly fairladies:
1. 280Z
2. Z31
3. Z32
I've never met him. Just occasionally interact via the aus300 forums.
I agree on the Z31 for sure. I can't see anything attractive in that car. Does absolutely nothing for me.
Blipman's Z32 was pretty nice I reckon.
What's wrong with a VH45?
LSx's are lighter, cheaper and more reliable.
oh... lol yeah I used to sit about 2m away from him every day at work for a year n a bit. reminded him almost every chance I got.
I've got a nice 300ZX right here for you :P Haha.
:P
Even if it was twin turbo, I would not take it.
congrats, you own the 3rd ugliest Fairlady of all time.
:cool:
I do, on a regular basis. That's why he went and bought an R33 :P Anything's an upgrade I suppose. Then he got a 180sx and then a Smellsior. Also if you see Ben, tell him I said hi, haven't seen him in over a year now.
fugly fairladies:
1. 280Z
2. Z31
3. Z32
LOL!
Only reason I would take a 280ZX is cause at the time, it was hard to a 240Z / 260Z.
I would still prefer a 280Z over the Z31 and Z32.
At least it retained some of the classic shape / styling lines.
240Z / 260Z = all time best Fairladies!
Not much of a fan of the newbie 350Z and 370Z's either.
given a supra, 300zx and a mr2, I'd probably take the mr2 over the lot. fuck driving land barges off. at least an MR2 turbo is zip zip fun times.
i automatically assume anyone driving a 300zx is in their late 30's and working some entry level job (can't afford anything better).
poopra drivers are hard to predict, they're either tossers like 3 series BMW drivers or they're guys who love drag racing but got snotty with the fact that power windows don't come factory on commodores.
:P
Your opinions amuse me and the fact that you are usually spot on.
:cool:
I think you should sell it and the Supra and buy a GTR.
Yeah. Will be R32 GTR or a modded MR2.
There seems to be alot of MR2s popping up for sale now with forged rebuilds and everything done. They're going for relatively cheap too. Much much cheaper than a GTR.
So when the time comes I will look at the wallet and make my choice then. Either way I'll be happy.
I've never driven a GTR but I did drive Chad's GTS-T and loved the feel of that. Have driven an R33 and it really did nothing for me.
I think I just prefer slightly older cars.
Edited by jezza boii
Sounds like a plan!
a GTR is nothing like a GTSt. nothing. they just have the same headlights.
True that!
wait till you drive one.
Hell I even got to drive a 200ZR with an RB26DETT and I was like "sweeeeeeeet", started the car and took a corner and went "FFFFFFFFFUUUUU".
first day at cadbury = great success
First task was taste testing cherry ripes :cool:
Picked up 5kg of Picnic for $8, will get a box of boost tomorrow :P
haha you're so getting diabetes.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
