Need more boost, switching the blitz spec s for a spec r, running decat then send away for retune. Hopefully trent with his wisdom will make me crack over 300rwkw on about 21-22psi. 280rwkw is too slow now :action-smiley-069:
trent is awesome he knows his shit thats for sure i asked him some questions when i was picking up my brothers car and he knew the answers in details :action-smiley-069: also you should convince brent to get a new turbo lol
lolol k its happening in june. Car will have about 35-40kw more in the midrange and should get close to 300kw, im excited :wub:
LOL do i have to take him for another drive to convince him?
huh? lol
lol his got some wheels coming from jap his gunna be selling them white xd9s they are 17s but mad offsets
not a big change from what u have though but *meh*
think i saw ur mate at the gym with the white ford forgot his name so didnt say hello or nothin lolss
was a waste of a story imo.. see the red porsche?
nah i was like cbf watching and went for a run haha
hmmm 18x9.5 +18 desmond regamasters for my evo?
considering they usually go max of about 18x9 +30 on the ct9a chassis unless they widebodies
went to a muscle car show yesterday at flemington and it was awesome, no matter how much i like skylines and jap cars they can never beat the sound of old school muscle cars :happy: hear are some pics:
check out the size of these tyres, they should fill the guards on a gtr lol.
id love to own so many of the cars there, especially mustangs they are my favourite. so are camaro's and the impala's and the pontiac gto's and plymouth cuda's are hot also, too many to choose from ;) .
haha its always from NSW
and they are usually lebos that are the hoons
bahahaha lebs
my leb mate just bought a VT commo
going for the 20 inch clubby rims and dump treatment soon
was flicking thru the channels before and came across this program on the ABC
dont know what it was about but it showed the arab that got caught from the bob jane riots going off at the camera man because he called his dad a terrorist..
interesting.. arab + beard = terrorist?
mmmm 1968 RS Camaro
apart from the bonnet exactly like my dad's one (his is plain)
oh fk! forgot about that damn
I went to the classic euro carshow back in Feb.
Saw the merc gulwing and lotus esprit amongst all other cool cars haha
wish my dad was still into cars, but he is a loser now lol.
my dads a bit in the middle.
he likes cars but he's a very sensible person
so just when i think he is actually going to buy something exciting. he decides to invest the $$ instead
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
