bigpond cable 50gb plan, 30+ mbps do i win the internets?
half price ftw.
yeh i hated my old 4 door rear, although it was series 1 looks a little better when you paint the middle garnish. (looks a little more like 32 4 door rear lights still ugly but better)
half price ftw.
Lol if it's in your bros name you don't get half price. You get 25% off stooge lol
more paper..... even if it clogs up when you flush
once you walk away its not your problem anymore, let the next person deal with it
bahahahahahahahhaha
sif you dump in public toilets. that shits offfff
Im after a (legal) gun range where you can try out guns (pistols, snipers etc) Anything like this in Victoria?
I went to one in QLD on Hamilton Island http://www.hamiltonisland.com.au/target-shooting-range/ but trying to find something here
as if bomb public toilets.. nastty u catch rabies in public toilets..
I go bombs over baghdad styles at work. Company paid crapper time FTMFW. Gotta get in before 11am though, cos then its all fresh like from the previous night's cleaners.
I know of some clay shooting clubs around franga ,mornington..beleive there used to be a gun club in clayton somewhere too...Not sure if this what your looking for but...
Im sure if you ask the guys at the Gun shop in Frankston they'd point you in the right direction...
http://www.truelocal.com.au/business/miall...-shop/frankston
bahahahahahahahhaha
who said public? ..... i was talking about at home :P
there is one in Little river on the way to geelong, right next the the paintball field they have there now..... its at the back way off the highway, and a little hard to find if you dont know where your going
been to little river, dont think they have guns to "try". they probably have club guns to use if you join.
i have heard of a rang in melb that does what u ask, NFI where it is though
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
