MR2 turbo...
The current rims fail.
See here: http://img197.imageshack.us/img197/2161/mr21.jpg
christ... did they come off a commodore?
errr... you'd want something roadstery I guess... or ferrarish.
Yeah, something fairly simple but effective. I like chrome lip.
I'd prefer 17s coz 18s require guard rolling on an MR2 in most cases.
Need wheels asap for RWC... Otherwise I would spend the extra time getting guards rolled and what-not.
17s are heaps big enough for an MR2 anyway, considering they come stock with 14s or 15s.
depends on the car you wanna put em on.
learn to walk before you try to run dicksnot.
i do know how to run
lick my balls
jezza-gtr
i want something that can be modded.. again, if they dont approve an r32 gtst ill go back to the r33 na plan
lick my balls
jezza-gtr
aren't the new laws that you are not meant to add any mods?
yeah I'm leaning towards light blue too... it'll be a flat blue though, not metallic like that sample
eighter chrome on ultramarine blue:
or go full chrome on traffic blue:
gold on traffic blue:
liking the light blue though:
im a f**king arab.. we try and get away with what we can lol
id go with the dark blue like the one on that pic of the m5.
+11111tyy
that looks tough as nails. do it
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
