he's the second in line of the circle jerk. that's his official position. true story.
So he is a circle jerk?
:bunny:
Oh and Jamie you will prob know about this
noticed Alex has his r33 gtr veilside back. They end up fixing the stuttering problem or gave up? Ifbthey fixed it I'm stopping by their workshop haha
Ah yeah,
Ray from RE Customs fixed the problem.
I spoke to him briefly and from memory he said that there was a slight leak in the Inlet Plenum which was causing the stuttering.
I am sure there was more to it but that's all I got out from Ray at the time.
It's a complete car now with Veilside Andrew Evolution X wheels, which came off a 180SX.
You remember the last RE Customs Dyno Day and a white 180SX was there... (The one that pulled 319 rwKw's)
The Veilside wheels came from that car.
soo smooth
http://www.stanceworks.com/?p=8447
funky get on it
that is EXACTLY the look I'm goin for, but with dished work meisters and metallic paint instead of matte. Dunno bout the oldschool mirrors or the plaid interior, going with a tan leather trim.
he's a member of a circle jerk. yes. actual fact.
LOL!
soo smooth
funky get on it
Love Satin Paint.
this year... events
and circle jerker of course
Haha!
Nice!
WORK Meisters = Awesome!
Go satin paint...
So that exact look, minus the wheels, paint and interior.
$600 p/a for the R32 and $400 p/a for the golf. giggity.
Not that I've been at fault in the last 8 years.
hey funks where do you get your ultramarine paint from?
shouldnt any body shop do it?
need about 2 litres of it
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
