lol $4500 is about 75% of the price of your car. Why not sell and trade up with spare cash? betcha an R32 GTR (should come within your budget if you sold the gtst and added the extra cash) with a service is as reliable and fast as your GTSt.
haha tell me about it!
Im in too deep to sell up now, would be a lot of money wasted haha.
200k service done and everything else pretty much replaced, should last me to 300k :blush:
Biggest pain was my rebuilt brake master cylinder decided to leak (after 2yrs). So ended up buying a brand newie
F*ck yeah. Took a deposit on my Supra yesterday!
I too would like to make a deposit on your supra. I'll even give you a couple of options... bonnet or roof, and swirls or stripes.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
