i got footwell neons its too dark in teh car otherwise.. having said that im use to the is250 which has footwell lights plus sat nav screen so its quite bright at night.. skyline feels like im driving a closet at night
lawl
On another note finally got some more people interested in my car woo
I've made a soft spot for Evos.. :)
ct9a's? :P
Did not :P Got them for free. Put them in coz my girlfriend likes them :)
..Okay, maybe I kinda like them too :D
ghey
Yeah, when I've got my targa shades in it's too dark. If they're off then I get heaps of light from above. Girlfriend still reaches over and flicks the switch on anyway :P
probably the same kind of person that'd buy an N/A Supra...
A P plater who wants something faster than an N/A Skyline? :P
R33 GTS25 = 140kW / 1390kg
Supra SZ = 164kW / 1460kg
R33 = 101kw per tonne
Supra = 112kw per tonne
Edited by jezza boii
fact sheets dont do shit.... actually drive the cars to see
every engine will produce different power from factory, every driver is different
either way r32 > supra anyday... even if the supra faster
cause they :P
Well of course people on SAU will say Skylines are better :P I'm indifferent because I'd prefer an MR2.
At the end of the day, the point I was trying to make is that a Supra makes a great P plate car. Reliable and still quick enough to have fun in.
Just look at Kez - at SAU events he's down there ripping around the track in his Supra, giving everyone a run for their money.
Whether you like the looks of them comes down to personal taste.
I prefer the look of R32s over Supras too. I almost bought an R34 instead, but it was too sluggish.
So, you finally sold all your cars... Almost (Supra still needs to go).
Finally put it into the MR2 Turbo and actually come out on a cruise.
ive got an evo though :D
I haven't had the other 2 for agessss man :P
But yeah, Supra was meant to be gone today but the dead battery screwed me around.
MR2 should be 100% functional pretty soon :D Then I'll come on a cruise or even organise something myself.
    • Saw this video today from Adam LZ.    Long story short is he is claiming that the load from the engine fan once the fan clutch heats up(engaged) is increasing the getrag rattle(at idle) when you don't have a dual mass flywheel.  Before I go buying an electric fan setup .... Anyone heard of this ?    I must admit when my car is cold the getrag is pretty quiet and I do notice the rattle after it is all warmed up. I've always assumed this is due to the gearbox oil temp and tolerances of metal.
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
