yeh and so am i :) haha
yeah.. which area? :)
"your mumas so fat. last time she tried to eat healthy she dipped the carrot in a tub of butter"
"your mumas so fat, the only reason aliens dont invade earth is because their scared of her"
i dunno what its called, like i said were always in bed so im not after names of the places we visit
Yup! And luuurrrrving it :)
haha
just dont let bozodos see this
edit: what do you guys think of my magazine letterform?
are you doin work for aaron?
also what does a shitty grunge font have to do with imports?
whos aaron?
thats my vcd project.. slapping together an import mag front cover. been experimenting with different letterforms and thats the best one yet
and if you want to critisize, do it constructively :P
grunge was cool in the design circles two years ago, about sometime last year some twats made a photoshop brush and some fonts that had the grunge effect pre buttfucked into it, which brought in the scourge of 16 year olds with pipedreams and poorly aimed hopes of becoming overnight sensation designers. So they started covering that shitty little cesspool of the internets they occupy called myspace with that garbage.
So with that in mind you fail at life because:
You used a Geometric typeface in a context that doesn't require sophistication.
You made a limpdick effort at making the typeface modern/relevant by choosing a pre-grunged variant or hand grunging it.
You decided to call your made up company the same name as Aaron from Monster's original business name.
Fuck you, fuck your ambitions, fuck your aspirations and your shitty ass magazine letterform.
Here endeth the Art/Science lesson.
grunge was cool in the design circles two years ago, about sometime last year some twats made a photoshop brush and some fonts that had the grunge effect pre buttf**ked into it, which brought in the scourge of 16 year olds with pipedreams and poorly aimed hopes of becoming overnight sensation designers. So they started covering that shitty little cesspool of the internets they occupy called myspace with that garbage.
f**k you, f**k your ambitions, f**k your aspirations and your shitty ass magazine letterform.
cool, say what you want. its just something im whacking together for class. dont really give a f**k about where grunge letterform came from. i dont give a f**k if you think its shit. the target audience i surveyed liked it.
perhaps hinting on what else could look better etc rather than sit there and rant about a letterform.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
