yeh and so am i :) haha
yeah.. which area? :)
"your mumas so fat. last time she tried to eat healthy she dipped the carrot in a tub of butter"
"your mumas so fat, the only reason aliens dont invade earth is because their scared of her"
i dunno what its called, like i said were always in bed so im not after names of the places we visit
Yup! And luuurrrrving it :)
haha
just dont let bozodos see this
edit: what do you guys think of my magazine letterform?
are you doin work for aaron?
also what does a shitty grunge font have to do with imports?
whos aaron?
thats my vcd project.. slapping together an import mag front cover. been experimenting with different letterforms and thats the best one yet
and if you want to critisize, do it constructively :P
grunge was cool in the design circles two years ago, about sometime last year some twats made a photoshop brush and some fonts that had the grunge effect pre buttfucked into it, which brought in the scourge of 16 year olds with pipedreams and poorly aimed hopes of becoming overnight sensation designers. So they started covering that shitty little cesspool of the internets they occupy called myspace with that garbage.
So with that in mind you fail at life because:
You used a Geometric typeface in a context that doesn't require sophistication.
You made a limpdick effort at making the typeface modern/relevant by choosing a pre-grunged variant or hand grunging it.
You decided to call your made up company the same name as Aaron from Monster's original business name.
Fuck you, fuck your ambitions, fuck your aspirations and your shitty ass magazine letterform.
Here endeth the Art/Science lesson.
grunge was cool in the design circles two years ago, about sometime last year some twats made a photoshop brush and some fonts that had the grunge effect pre buttf**ked into it, which brought in the scourge of 16 year olds with pipedreams and poorly aimed hopes of becoming overnight sensation designers. So they started covering that shitty little cesspool of the internets they occupy called myspace with that garbage.
f**k you, f**k your ambitions, f**k your aspirations and your shitty ass magazine letterform.
cool, say what you want. its just something im whacking together for class. dont really give a f**k about where grunge letterform came from. i dont give a f**k if you think its shit. the target audience i surveyed liked it.
perhaps hinting on what else could look better etc rather than sit there and rant about a letterform.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
