picked up PFC for $800 secondhand for my old 32 GTR about 3 years ago, got a PFC for the S14 new from japan delivered for $1250 about 2 years ago.
surely it can't go up in price.
sif run a PFC these days anyways when there's other ECU's with better sampling, non proprietary interfaces and allowance for many more ancillary switches and signals, including OBD emulation.
ecr33 gtst are out of production, but gtr arent. this was a year or so ago when apexi went bust
apexi isn't bankrupt. they're still carrying out business as usual. some smart sellers have used this excuse to bump up prices.
Apexi did reshuffle their powerFC lineup though. They relegated units for engines that were 10 years out of production to the Apex Engineering line, and only kept the ones newer than 10 years (hence RB26, SR20, RB25 Neo) in stock and available off the shelf. The older units are still available, but as special order at minimal extra cost.
just cos your agent can't be arsed putting in that order and then getting it to you, does not mean that it's not available or should be much more expensive.
damn straight.... if i was buying right now i'd go a vipec.... WANT... CYCLE... IDLE....
yeah why is it that ECR33 PFC more expensive than BCNR33 PFC ?
im guessing demand?
NEC stopped producing the chip used in the 25det unit
no... it was before that happened... see above :rofl2:
for stealth/price nistune is king
for functionality/value vipec
for street cred - motec
bahahahahahhaa
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
