yeah its awesome, i saw it not that long ago.
haha watched it couple nights ago, the lambo part with danny divito was hilarious
old russian guy came up to me the other night started talking about skylines
said he used to have a 32 gtr and kept telling me how they fast like planes!
nice bloke - said he gave it to his nephew and put a new heavy duty clutch in it, wonder if its someone on here!?
:P
they have some serious cars in russia
been there. its that fancy french joint yeah? felt so out of place there haha. my fav used to be squires loft in the cbd, but they've moved and it aint as good now
City Grille Room is owned by the same people, is cheaper and good :P
that was awesome, also how he uses the designer handbag to hold those lollies in.
In Russia cars drive you.
Newayysss who's going to autosalon? Come say hi if you are. I'll be there all weekend. And I'll be wasted haha
ill probably go..
also, added you on psn with my new account. just cant play cod coz im capped lol
autosalon probably.. most likely go @ night but cos i work weekends may as well support the car scene ill probably hate alot of the cars but meh
im in it for the b00bzors!
I might go in early to avoid the line up... But think the line should be ok...
LOL! @ b00bzors, get your camera ready.
I remember back in '07, I went to Auto Salon at like 3pm on the Sunday and the awards were on so there was no crowds around the cars and only at the stage, so the whole place was free for me to take pics of cars without ppl walking in the way.
Hehe!
lol true i hate the hectic 16 y.os the most.. that talk the biggest shit ever have f**kin no cluee they give me a migraine..
OMG U LEH BROOO WHEN IM 18 LIKE MY MUM IS GONNA LET ME DRIVE HER VY CALAIS SUPERCHARRGGGED PWOAHHHHHHH!
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
