sooo.. how powerful would one of these be with a 350Z TT setup
I think APS made the 350Z run 12's.
the silver 180 low as fk and certified gangster?
Yeah that's the 1!
probably a panhard flat twin
I see, thanks!
Ppfftt shan. You will only get a little respect when you actually have a car with hellashit fitment.
If you mod your car to get respect from others you should work on your self esteem :/ sorry but you just sounded really silly saying that
you're the one who implied that we mod our cars for the respect of others retard.
because it's a DB HBR5, not a Fairlady Z as the filename suggests
Yeah, I was just doing a little reading and it saying it is a 2 cylinder sub type "Boxer" engine.
Seems to be more of a motorcycle engine.
Cool!
Thanks again.
yeah, looks awesome
also a black one at the electricity joint up mahoneys road, red p plater, primered patches all over the car, flared guards and some sweet sweet fitting dteks
cracked a stiff while limping to work
lol that's ghetto... lotsa maccas wage rolla boys do it and think it's the shit.
but if you are gonna do it, at least turn it the other way around and bolt it to your bumper.
failing that just get a ghetto spec 180SX bumper lip, turn upside down and fit to R32/33 bumper.
its 'L' shaped. will be bolted.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
