pigs arse, we've fitted about 3 sets on cars, and they were almost identical to the other equivalent stuff from race logic and G4/D2. Just powdercoated a different colour. Shit we even showed the race logic guy who looked after our trade account and he was like "ummm yeahhhh funny that".
8/4? you had better spring rates when you were rockin superior stock suspension for acceleration.
shan is right. BC is another version of G4 Racing coilovers and D2. same parts used just different label.
why is it so hard to get r34 gtr suspension parts? first of all ive got all these suspension places online saying these caster rods fit r34 gtr and they dont its a way different shape in the r34 gtr's its driving me nuts so now im seeing if i can buy just the bushes. also i cant find any tie rods and tie rod ends either.
on another note ive got some caster rods that will fit r32 and r33 gtr NOT R34 GTR! im selling them for $150
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
