I got my rally day in november! Driving a Evo 7 round a rally track. Hope they got insurance! hahaha
Say whaa, nuh this one is in werribee
And says your choice or a Lancer Evolution 7 or a Subaru WRX
We got choice of Evo 6.5 and various vintages of WRX. You'll enjoy it, but it doesn't go for long enough.
didnt even no the stance/hellaflush scene was so alive and well over here especially in vic. saw the white oddyssey with the chrysler? badge thing on the bonnet and 'USDM' at autosalon. both cars look schweet. im lookin for an old datsun 610 that i can flush up.
Block off BOV
errr.... why?
lol what idiot told you that? you know that doesn't apply to modern (post 1990's) gearboxes right? they engage syncros as soon as you push the clutch in. I put it to you that you're fucking up your syncro's MORE by jumping on the accelerator like a tard and not matching revs to gears exactly (ie not needing to use syncros) while using your clutch still while you "heel-toe".
Also, syncro gears cost less than drive gears to replace. Unless you're driving an auto, in which case heel toeing is 100% retarded.
i need to heel toe because i run a HHHDB clutch that bites like a bitch unless the revs are matched
Has anyone really been far even as decided to use even go want to do look more like?
what THE FUCK?!?
hmm factory nissan sr20 injectors are purple...my sard injectors are purple. I wonder if that will slide with EPA.... Im sure they dont know the colour of every injector for nissan variants? lol
yes they do... hey have a book...
but purple/purple will probably suffice
