make sure you upgrade your pivot bolt, fork and the right size throwout if you're getting heavier button clutches.
chucked my OS Giken triple in and after one track day couldn't put it in gear. turned out the factory fork and pivot had warped/snapped. another guy who came to the workshop used the factory throwout and fucked his clutch up after one track day.
haha costed me $220 all up with rims
his sending them to a depot in LA where ive got a mate that brings in his stuff from there
and my mate not charging me to ship it here :down:
Sweeeet - have you figured out how wide your flares need to be?
nah not yet, unsure on the exact offset of them yet.... would be massive neg thats for sure lol
once they get it ill test them up on car and measure it all up and go from there
reckon itll beed about 3inch flares though, cause i think the rims are about 8"
tl;dr
summary?
Integra driver failing to understand that venting hot air out of the engine bay is beneficial.
I have another screen shot at home of him telling people that getting water in your pod filter will cause you to blow a tie rod.
Brings the lolz.
who can weld stuff for me? small job, need to chop off a bit of exhaust and weld on a flange and a bit of straight pipe.
anyone? plzzzzz, wanna have car ready for Buller cruise
mmm i can weld, but wether i cbf lol
cefiiiiiiiiilo! with S14A front conversion. and R33 GTR style front bumper. think it's in thailand or malaysia.
Fuck, you know everything!
LOL!
It was in the Internet Movie Cars Database (IMCDB) listed as unknown and no one can tell what it is...
I dunno if i can trust 'you people' haha..
Do you have the equipment? I pay cash ;)
'you people' mayteeee comon..... dont be lyk dis, you knw we gud at wat we do brutha
you pay kesh? thats all dat matters mayteeeee
yeah dunno how much mig gas i got should be fine though.... aslong as the pipes arnt stainless i can do it, dont have a tig
oh if it's in a movie, then it'll be malaysia for sure. they made a couple of drift movies in F&F style. one of the baddies drive a cefiro with some work done to it.
actually. hold that thought. A pillar gauges on the left. must be LHD, which means it's in the phillipines.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
