Gee, your 34 is really pain in the ass...
I just did some maths, it seems this car has been in a workshop for 92% of the time I've owned it. And in the last year, this daily has done 0kms! Luckily with that much driving, it was comprehensively insured and registered the entire time!
Boy, I love my automobile!
... Fuck no!
Shit!
planning on doing this to the 32.......
edit:
ffuuuuu. noone can help me work out what colour the paint is.. is it light grey metalic? or light grey blue metalic or the 11ty billion other things i have read
Edited by Mohsen
andddd
also noticed my front brakes are massive and my diffs are finned
theres a bees dick clearance on the s15 stockers and they look alot bigger than another R32 gtst i saw with 17's
did the gts4's have the finned diffs too?
colour is on your build plate retard, get the code and google it.
they all have "finned" diffs, non GTR's have smaller fins. Brakes are the same as R32 GTSt.
yeah i had a look at the build plate and it says its Tg0.
all the paint code threads have an asterisk next to the code. what does that mean?
also put it thru some online paint code fast and it said its blue grey metalic light bla bla bla
im confused as shit
Holy moly!
And you should go to workshop with a cake to celebrate.
im confused as shit
not really going to matter anyway
even if you need to get parts painted the car has the paint code on the blue plate,
when they search on the paint charts on the computers at panelshops they will still get the colour
Daily. Spent a ton on a shift kit from MV autos. I generally like the ability to just put it in D when I just want to get around town. Its an option but f**k me its an expensive one especially if it's not necessary :(
I really hate that excuse. Just cause its a daily doesnt mean shit. Majority of skylines on this forum are daily and they arent all rolling around in D. Every auto owner says that excuse... Not paying you out specifically just the majority of auto drivers haha
If its a specific, specialised problem, you are probably better off doing your own investigating/research to work out what it could be and go down that track. Mechanics dont have time to spend billions of hours working on a problem they will never see in another car. If you want to be exclusive you will need to research yourself else drop a manual box into there and be done with it.
I think its time to fix my mexican fitment...
17x9 +30 with 225/45 for front (upgrade 8inch to 9inch)
17x9 +30 with 235/45 for rear (downsize my 255/40's)
and moar lows? Find me a good pic of r33 gtr rims on r32 gtst. Same rim specs. kthnxbye
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
