Yep, a cock juggling thunderflamin mongrel. Then I told him to look up the definition. He spent the next 10 minutes on urban dictionary :)
Edited by jezza boii
Well I went the high road and told them... they said good on me for saying something. All good, although I'm pretty excellent already so I don't think this made any difference to my Brownies Points. It's a bit like in Zelda when you are full powered but still can't resist catching all of those little hearts :) mmmmm hearts.
Alex, I work for CGU Insurance :worship:
you were sounding cool and shit up until this point.
Good point. I like to mix it up a bit though, try new beers etc.
A slab of Coronas will never go wasted though :P
EDIT: Ric beat me to it :down:
the mrs and i drink usually
~2 slabs a week (usually 1 corona and 1 hieneken imports)
a different beer from work as my knockoff 5/7 nights
a case of wine every 2 weeks
a bottle of belvedere a fortnight
bottle of cognag/armagnac a month (mrs don't touch this)
so i get plenty of "variety" :down:
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
