is your moms gonna be shotgunning so you can drive on the cruise?
looooll well played
cant actually leave the house at the moment, not till the old man comes back from OS
on that note, going to book p's on wednsday next week. woot
Edited by Mohsen
If you after an awesome beer try Zywiec. Polish beer, will only find in specialty shops of the bottle-o on Brady road, Dandenong :)
Every Polak will swear by its awesomeness taste.
A good German beer is Hasseröder. A lot of German towns have their own local brewery. This is the beer of Wernigerode. Really nice beer!
and by specialty shops on Brady road, you mean...
Zywiec is available at Dan Murphy's...
Kris has the stuff at work all the time. the normal one and the stronger one.
Speaking of alcohol....I gave my mate about 10 ABC/absinthe/151/Chartreuse shots in the space of an hour or so, most of them chased by skulling vodka or jager bombs...
to my dismay he stayed on his feet for quite a while before later vomiting up some blood and passing out for an hour or 2...he made it back to the club though...gotta respect him now..
ah ye thats right! Pricey though! I got 5x500ml cans + a free glass for $12.99 on brady road. I think its $4~ in Dan Murphys?
Another good drink I only recently discovered is Captain Morgan rum. Mix it with Coke, and it taste kinda like creamy soda. Polished off a bottle of it one night in Perth a couple weeks ago. The outcome = f**ked!
It's about $4.50 for a 500ml bottle at my work pat. We only had the cans for a shirt time. Vb is a disgusting beer and the people who come in and buy it reflect this
remember it's a bittter, so you cant compare it to heineken, zywiec etc... or even carlton...
go drink some other bitters, like xxxx or tetly and then realise it's actually pretty bloody good for what it is!
I really don't like Carlton Draught, even though many people will SWEAR it's the best beer ever.
I like a lot of imported beers. There have been a few aussie beers that have impressed me though - Coopers is one of them.
i dont mind carlton draught, but i usally buy light beers cos they taste better
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
