is your moms gonna be shotgunning so you can drive on the cruise?
looooll well played
cant actually leave the house at the moment, not till the old man comes back from OS
on that note, going to book p's on wednsday next week. woot
Edited by Mohsen
If you after an awesome beer try Zywiec. Polish beer, will only find in specialty shops of the bottle-o on Brady road, Dandenong :)
Every Polak will swear by its awesomeness taste.
A good German beer is Hasseröder. A lot of German towns have their own local brewery. This is the beer of Wernigerode. Really nice beer!
and by specialty shops on Brady road, you mean...
Zywiec is available at Dan Murphy's...
Kris has the stuff at work all the time. the normal one and the stronger one.
Speaking of alcohol....I gave my mate about 10 ABC/absinthe/151/Chartreuse shots in the space of an hour or so, most of them chased by skulling vodka or jager bombs...
to my dismay he stayed on his feet for quite a while before later vomiting up some blood and passing out for an hour or 2...he made it back to the club though...gotta respect him now..
ah ye thats right! Pricey though! I got 5x500ml cans + a free glass for $12.99 on brady road. I think its $4~ in Dan Murphys?
Another good drink I only recently discovered is Captain Morgan rum. Mix it with Coke, and it taste kinda like creamy soda. Polished off a bottle of it one night in Perth a couple weeks ago. The outcome = f**ked!
It's about $4.50 for a 500ml bottle at my work pat. We only had the cans for a shirt time. Vb is a disgusting beer and the people who come in and buy it reflect this
remember it's a bittter, so you cant compare it to heineken, zywiec etc... or even carlton...
go drink some other bitters, like xxxx or tetly and then realise it's actually pretty bloody good for what it is!
I really don't like Carlton Draught, even though many people will SWEAR it's the best beer ever.
I like a lot of imported beers. There have been a few aussie beers that have impressed me though - Coopers is one of them.
i dont mind carlton draught, but i usally buy light beers cos they taste better
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
