you should own a regular car before you take on the headaches of a classic.
put it this way, this car's gonna be driven hard once a week. if it breaks it'll go into a workshop while I drive a daily. you, on the other hand don't have that luxury.
i got my parents cars in case something breaks..
anyway, off to sus out my spark plugs and coils again
dude its not hard to suss out what the problem is. Start the car, let it idle. Go to your coilpacks. Unplug the coilpack connector. Change of sound? If not plug back in, and continue through the 6. If there is no change of sound then that coilpack is farked. Replace it, end.
If it doesnt turn out to be the coilpacks, then look towards the injectors. See if any of the plugs has come loose. If it aint the injectors or sparkplugs, it could be the ignition module (the black thing ontop of the cover you remove at back of engine)
the only difference between when you got the car and it running like ass was your brilliant stroke of genius to "reset the ECU". what did you do to reset the ECU?
do NOT do the "tape the coilpacks mod"
i did that, car drove fine for a day or 2 then whenever i put my foot down hard car went nowhere...literally
took out coilpacks and the tape had melted loose and was all over the place
stupidity on my behalf but meh live and learn.
resetting ecu (disconnecting negative terminal for a day) is fine, ive done it heaps of times with no probs.
are you sure you havent unplugged anything and forgotten about it? or any loose clamps etc?
go over your engine bay and check all hoses/plugs etc carefully
just my 1.98cents
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
