Cuz your R33 is causing you headaches Haha!
R34 GTR would be sweet, we all know that.
So do it ;)
So true!
Might sell it aggressively after DECA (3 weekends away).
Man, you don't fuck around that's for sure ;)
But I guess, the easy accessibility you have to high performance imports, you'd see so many of them, you get use to the high turn over...
S30 is like my childhood dream car. I came close with a corvette stingray, but I'm determined to have one in my life... which means any run of the mill GTR will get the flick in preference.
I plan on spending a bit on it too. tubs, S15 dash conversion etc, cos it's a bit ragged on the inside and can do with some paint.
I need to start sellin cars too... which means I need to fix some of em... Who's a good workshop in the SE that can diagnose R32 ABS problems? I think I've got a blockage in my brake line, but cbf pullin it all out and checking.
Yeah for sure!
Well I'd take it to my mechanic but they are in Templestowe.
In the SE, I'd say Race Pace / RE Customs.
this was much easier when driftline was around, just drop it off and pick it up, buy lunch, beers or stippers as payment.
might ring up monty and see how he's goin at chasers n if he can get one of em to look at it for me.
femno heyyyy... hmm might facebook him
whats a decent targa top car other than the usual 300zx mr2 etc?
Aerotop Supra (especially TT version) wouldn't be bad.
Pontiac Trans Am (if you're into American muscle)
Ferrari F355 (if you've got deep pockets)
NX, Exa, CRX etc. are all shit.
That's about all I can think of. Other than the Ferrari, I think an MR2 would probably be the best out of that bunch ;)
A 2000 spec 300ZX would be sick, but they're rare as.
I agree that there should be a bigger market. I love targa tops. I reckon RX7s and RX8s would've looked wicked with one. Same with S14/15s.
better remove it from your cars list then, Mohsen ;)
lmao
fixed the r32 ;)
also, spotted an R32 GTR at Creatd. same colour as my car. its so light compared to gun grey!
Edited by Mohsen
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
