its against some religions to touch spiders abdomen's. not that i care, but just thought it was interesting.
fuck them pansy ngas.
altho I used to own a pet tarantula. so meh. he was mad fluffy and shit.
also, thorax is not abdomen. thorax is their chest, abdomen is their tail. if you pick a spider up by it's tail it could splode or shit itself or bend over and bite you. thorax is like ultimate body grip.
That gave me cold shivers. I'd pick up a daddy-long-legs, nothing else.
Make a donation to SAU so they don't need to have advertising :whistling:
haha yeh right not since i keep gettin warnings/bans LOL
plus im not against the advertising just the drop down form of it realllllllllllllllllllly effects my time on the forum.
f**k them pansy ngas.
ew spiders, they don't play with you at all, boring..
my cobalt blue bit me, looked pretty though.
It died because i went to the army and no one gave it water, HAHA.
what about one landing on your arm while its hanging out the window while driving... and then people look at you like :whistling: when you look like your having a spaz attack trying to get it off..
way to fk up a good mercedes
ok both pics are chops, but the car has potential. 1.6l turbo awd manual. goes for 13k GBP so should see around $25k here w options etc. i'd have one over the cube, just gotta get rid of the round front lights
it's the replacement for the micra.
you know, that's actually worse than a golf.
deal w/ it.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
