lolol. tpg on telstra DSLAM = fail
TPG on TPG DSLAM = win
also I ripped out all the old shitty wiring in my house and laid down fresh Cat6 cable and got telstra to come change the cable from the post to my house to a new one as well before I ditched them for TPG.
result... getting 1.5Mb - 1.8Mb (megabytes, not bits) per second on torrents.
Don't bother with customer service though, it goes to Phillipines and sucks donkey balls. Also the phone is changed to a VOIP line if you switch to a TPG DSLAM, which can suck if you're dependent on that sorta shit liek with an alarm or sending faxes like a povo kent.
Not sure what all the tech geek speak meant, but I'll pretty much only get a phone line installed at the house for internet...No need for a home phone when I've got my mobile anyway...
so how would I go about getting the good TPG you speak of? House is brand new in a brand new area too, so all the cabling will be new.
was on TPG yeah did disconnect alot specially annoying when you're trying to download stuff. no not porn.
any suggestions for nice 2nd hand meshies or similar rims for bout 1k?
sif dl porn anyway. stream bish. like you need to look at the same shit twice
can depend on the housing committee that control your estate thing. mine weren't smart enough to lay any foxtel/intenet cable. im running foxtel off satellite
life without foxtel is just not living...
Foxtel is a joke these days. The whole idea of pay tv is that there's no need for ads as you're paying for them
to run it... When we first got it back in the day ads were about 10 seconds long and only advertised the next show, but these days they're advertising products and run as long as, if not longer than free to air ads.
I download every show or movie I wanna watch and watch them whenever I want, with no commercials.
Dezz what estate you in? If it's around here I can probably give u an idea on internets
The Rise in tarneit
there's a bigger picture tho dezz... the adds NEED to be there
tv shows are made to be 22 minutes long and to keep them to half hour blocks they need to fill 16 mins per hour OR run shows at all sorts of stupid times, which pisses people off more than the adds do :rolleyes:
they also fill up slots with little shorts, but they get boring and annoying as they have to be repeated
the idea of pay tv is that you pay for more chanels and dedicated channels, not paying so you dont have ads :blink:
also nowdays on fox, 90% of the adds are for other shows on fox, and if i wanna watch it i just hit the record button and it will be there in my planner waiting for me :P
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
