now you know. lol anyone who goes on holiday to europe knows that BMW drivers are the silvia drivers of the EU.
haha, Aston Martins dont have a lot of presence here either. There are heaps of them on the street.
Did see the V10 Audi R8. Yum Yum
Oh and car feels sluggish in the heat, goes great on the cold, is it because the cold airboa denser tHan warm and shit? Fmic fix this?
yes. its called heatsoak. also dont thrash the car in the heat. common sense, and you have more danger of detonation when intake air is hot
lol 10 posts allow you to PM. a lotta guys post out of the blue to get to 10 then disappear.
but welcome. enjoy your stay.
wait, stop everything
funky being nice?
what have you done with funky you impostor?!
lol... what about when you rock up to a motorsport event on a 35+ day? huh? well? huh? whachagonnasaynow? huh?
funky being nice?
gotta be nice to the newbies. you, on the other hand, can fuck off ya cock galloping knob jockey.
sif race on a 35+ day.
yeah man thurs good for you? i feel asleep b4 and just woke up now
sounds good to me. thursday night? where at?
Also, walked past a Mazda hatch today in blue, and FFFUUU damn you Jizzy, now I'm thinking I should paint the golf in the same colour with a purple pearl in the clearcoat.
Haha dooo itttt! Mazda have been coming up with some really nice colours recently. Actually pretty much all manufacturers are coming out with cool stuff.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
