and this feedback system is not going to work properly they had this on nissansilvia and went out of hand.
This is a raw install, we've not really worked out what will/wont stay.
Trying to get it running first is the main issue
hardest oil filter to remove ever
stupid thing
and replaced my vac lines with 3/16th fuel hose
stupid things keep splitting so fuel hose it is
What motor was the oil filter in?
I think my GTS4 doesn't have turbo now...
<!--quoteo(post=5578258:date=3 Dec 2010, 05:07 PM:name=GTS-T_Sedan)--><div class='quotetop'>QUOTE (GTS-T_Sedan @ 3 Dec 2010, 05:07 PM) <a href="index.php?act=findpost&pid=5578258"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->TME are pretty good, mechanically they dont have the active rear diff like the 7/8/9 but that doesnt really matter
light than the 7s and heaps faster..... different seats and steering wheel than the evo 6, no radio, titanium blades on turbine.... thats all i can think of atm<!--QuoteEnd--></div><!--QuoteEEnd-->
no radio? f**k that lol
otherwise mmm interesting
Can always put one in, but its pretty much like an RS model just branded with Tommi Makinen shit everywhere
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
