i bet there is heapssss more to that kfc story even the article says that other customers have provided info that the people recording had been giving him shit basically.
i worked at maccas i understand how you could rage like that i mean, think of how many mohsens are in the world.
100% he was provoked... dun make it any less funny....
anyone got a blown r33 turbo lying around??
nope but i got a perfect one you can have for $300
https://manage.crucial.com.au/cart.php?a=add&pid=114
they're giving away 300 lifetime free 100mb hosting based in sydney. use free subdomain to make it totally free. Not bad if you just wanna host some files or use it as an email forwarder etc. never know when you might need it. it's free anyways.
If you want to get arse raped by cops yes lol. Replace then with 2860-5 :)
You can get anal raped for no water in washer bottle these days... I also considered -5s but found T78 kit for 1500 but 2 blade shave slight chip so dunno.
go big single grant, check out al's setup on his 3 litre
3076 external
Maybe I'll hit him up to check out his motor and take me for a spin.
Or I retune it and see if it is any better than before. If I change the turbo(s) it would defeat the purpose of me buying GTR with at least turbo upgrade in first place.
Stick with what you got man. It's good!
Remember Al's is a 3L
30et and rb25det pistons 1200 forged, you would be mad to rebuild to std spec if you ever did it
Haven't had to do it in a while, but last time I did, filling up a water bottle was a bit easier and cheaper than returning a car to stock to clear an EPA...
True true.
And found some oil leak on the R... Damn it.
Grant I think I'll be going with -5s once I got some cashola, I'd love a high mount but don't want the cop troubles - (more so I guess) anything above 350 awkw and I'll be happy obviously will be doing a lot of other stuff as well :D but just figured if I'm modding it I may as well make it worth while. Go for lots of power! you said you were bored of 300rwkw before remember :P
Also want some CF ganador mirrors and canards and looks wise will be done :D
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
