hey grant but i just happened to look at hamishes pics and the white gtr looks just like yours...you should get some parts off it and do the 32 up ..its got all the parts you wanted to make a 350 rwkw .................and no air bag steering wheel
The white GTR was mine, my next door tried to talk me into buying it back.
My GTR has already got N1 turbos so kinda pointless on buying a wreck to pick the turbos.
or save the money, sell the car and buy something you wont hate again next week?
That is the plan but as you can see I get distracted easily...
Should I cancel the F/S ad and buy the wheels off Shan?
It'd look good even if I set it on fire.
masssive wheels on a gtr is pointless they arent made for the stance scene they are for the go fast scene
who brought it may be thay can do a deal as i know you basically gave it away the next day and do a transplant for all the good bits into another 33..maybed a sleeper
Thought about that but can't be arsed, I've thought about buying 33 GTR shell and transfer bits but not sure if I want the effort.
If I managed to sell my GTR, I'm likely to buy 33 gtst.
would need epic camber or flare up front
I know, maybe 3 degree or thereabouts? Also stretch tyres, 225/45 or 235/40?
There's a set of 18x10 +18/9 AVS Model T5 for sale (same size and offset as Niroj's).
So I've got to decide whether to go bit naughty or go completely bonkers... Will decide when I've done the first step.
It'd look better on 33 gtst?
yerh cos why ruin a gtr with camber n fitment an shit
it is getting pretty annoying reading posts all day about you hating your car....in other words, it's beyond annoying so shut the f**k up about it
thought i was the only one who thought it was kinda annoying, if you hate it so much sell it
  • Like 1
fkn cant remember mang...
the rear's are set so they are almost flat on WOT (so like 1 deg neg mebbe?)
it's just done with superpro bushes atm, but will have to go upper arms if i go any lower
Selling the GTR now, may put it up on ebay tomorrow.
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
