ok hang on so the $2802 is what i pay per year and the "excess" which is $1600 is what i pay in an event of an accident etc? 3046 much safer than 3047 :P
what do yous pay then for your premiums?
With Shannons, Rating 1;
Cube - daily use cover, Skyline - extreme limited use cover, Pulsar - laid-up cover, approx. $170 per month.
If one's ecr33 diff has gone from a twin spinner to a single spinner akin to that of a VN commodore, what should one do?
options are:
shim
weld
replace with GTR diff
replace with real diff
all of these better than standard diff
options are:
shim
weld
Replace with GTR diff you say?
What benefit would this have over say, a train... which i can also afford.
options are:
shim
weld
Shim = what i will be doing
Weld = f**k that
GTR diff = will need to replace both half shafts as GTR is 6 bolt and GTST is 5 bolt
Replace with real diff = expensive and if u buy a shit one like i did it will explode nicely LOL
$10/month X 12 months = $120
is this your r33 or? why so cheap you must have a spotless license or something..
u think thats bad i remember being quoted somewhere round 5-6k full comp back in 2003 as a p plater r34 gtt think just cars or shannons.....
now $290 third party just cars.....
not surprised for a p plater i dont know what p plater would be able to afford that just for insurance anyway
thats not too bad for 3 cars but why do you need 3 cars for :/ i can understand 2 if you had 1 daily in which case i'd get a shitter thats not even worth insuring so i'd still only pay for 1
On a scale of 1 to Miley Cyrus, how illegal is shimming a diff?
you can shim a diff as tightly as you want, you can shim it for minimum lock or shim it so that it skips like a 2 way. Up to you.
With legality, its like anything if cops see it skipping they might say something, i have never had a prob with cops with the 2 way, they saw it skipping along the ground and didnt say anything
options are:
shim
weld
just went out for a drive to prac my heel and toe technique.......master :whistling: i notice that my diff feels a bit sad maybe its these f@#%in ku36's dnt like em time to get a real
diff nismo 1.5 or 2 way? yea boiii...
3 litre is probably cheaper
f**k welding the diff or GTR diff
either shim your current one or new kazz centre or nismo centre
do it once and do it properly
stuff changing in / out 2nd hand parts etc
kaaz 1.5
do it and you can thank me later.
shimming's good fun if you own a beat up 32, but if you want it to last, do it properly. Put it this way... ALL the power you make has to go through it. If you wanna wager that on a $1.50 shim go nuts.
shimming just increases the bite point of your viscous, which means there's still slip, as time goes on it'll wear down and cark your diff. Guaranteed. Unless you're prepared to pull down and flush pumpkins after every track day or major fang session.
kaaz 1.5
why kazz? they better?
??? how else do you drive around? I heel/toe for daily driving.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
