yeah peak power is only one part of the picture
if you look at my car its peak is pretty ordinary, 191 rwkw was its max
but the diff gears, lateral acceleration, suspension etc give it the quick accleration
able to beat most cars on "private roads" and was ever so slightly pulling away from a 315kw r8 ute on another "private road"
i still reckon on the street an 04 sti would be even - i dont know about "rip"
You were pulling away from a 315kw r8 in essentially a stock skyline. Me no believe
yep i kid you not
was about maybe 1.5 years ago
on a "private road" we both hit at 100km/h and i backed off we went ticked past $1.80
it was a blue R8 ute with the 315 badge on the rear of it, no idea if it was auto or manual
i was pulling away ever so slightly, only just
that was basic GTST with sub 190rwkw
my best 0 to 100 was 4.88 back in the old day
Maybe the guy couldn't drive lol. I managed to go door to door with those ve walkinshaw supercharged sedans on my private road. Later found out he had 357rwkw. I guess the weight kills those cars
Lol @ commodores. You'd hope 6 litres and FI would get you better than a mid 12...
  • Like 1
was getting paid last night to do absolutely nothing because the floors at work were too wet and slippery from the humidity...then when they finally got the place dried out enough to work, 2 hours had passed, so then had to work back til 4am meaning even higher pay rate...now they're behind so I'll be able to do the same tonight lol..good ole' humidity
FYI
pauls car = ~145rwkw/tonne
315 "kw" conformadore = ~250rwkw = ~145rwkw/tonne
power to weight is dead even
that's a rough calc taking your car as 1350kg and the R8 @ 1750kg with a drivetrain loss of 20%
fwiw on e85 my car is ~100rwkw/tonne more than holden's finest lol
lol...
it runs right past my house so make sure you drop in
will do. need monies soon to pay for engine build. they've got the EFI kit on the LS5 now, but they haven't got it running yet. Engine's good for 350 killabees with no EFI, so hopefully with it, should run a lot smoother and more powah.
Then if I have any money left over after moving later in the year strap a supercharger to it for even moar powah.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
