May I suggest masturbation?
Bit late for that Adam, I ended up watched some DVDs and had short sleep (2 hours).
The GTR is apparently fine so dunno why I sometimes have trouble starting it in hot weather ( sometimes have to pump the accelerator pedal) but it's fine in colder weather like today.
Oh man, my car does that too! When it's really hot outside the car won't start up / idle properly and I have to keep feathering the throttle for it to keep running. Does my head in.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
