Oh man, my car does that too! When it's really hot outside the car won't start up / idle properly and I have to keep feathering the throttle for it to keep running. Does my head in.
Yeah that's it.
How long have you had this problem?
What have you tried to solve it?
its the rmit in carlton so im guessing thats tafe
woohoo
anyway. some flamin mongrel broke into our front yard at work, helped themselves to our truck batteries, GPS and a shitload of tools
must have been midgets too, the hole was so fkn small
mohsen theres both uni and tafe there but mech engineering is at uni, I used to go there. I hope unlike me, you'll spend your time in lectures/tutes and not on the 3rd floor at the cafe playing pool.
Oh and for quality rmit chickitas, hit the arts/music/business etc buildings across the road :thumbsup:
f**k yeah..
Just had a Compact Fluroescent globe (energy saving) explode. Scared the fucking shit out of me!
Supposed to vacate the room because of the mercury, but it's a bit hard in a 1 bedroom apartment lol
Yeah that's it.
I've had the problem ever since I bought it 2.5 years ago. Basically when it's hot I know to keep my foot on the accelerator lol. It coughs and splutters for the first 30 seconds or so and sounds like it's running on 5 cylinders lol. It wants to stall desperately, but then it comes good.
I have a feeling it's the ignition module. Any suggestions?
those big halogen out door ones are LOUD. threw one into the skip at work, though its just gona crack.
throw it in, BANG! fkn shat a brick
in other news, had person with me today in my car, they go to to fiddle with the centre vent (they wanted the ac on) and the whole thing just crumbles....
now to buy a secondhand one..
the car should start the same if its hot or cold
do you mean the water temp is cold ,30deg ish and its hot out side 35deg and it doesnt start?
or after driving it, in summer, when you goto restart car whilst still hot, it doesnt start ?
Chatted to couple of buddies, one reckon it could be IAC or AAC or whatever valve but you mentioned ignition module...
May give it a go.
Bit of both, just struggle to start on hot weather even if motor haven't started in a day or 2.
One time, started it up no worries, drove to work, 7 hours later it struggled to start until I pumping the acc pedal for it to start.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
