same as my front bar series 3.. Red part is one part, the bar itself, black part is a plastic what Nissan call 'air spoiler'.
They can be seperated as they're only held together with screws.
ic. so where you buy it all seperate i only ever see copy bars which look like one piece ?
I didn't say you can't buy it with the bar, I said it's removable. My car is currently at the mechanic with the lip removed as due to pothole damage I've had to get insurance to replace it. Costs nearly 1700 for the black plastic lip alone.
Are there cheap copies? Who the hell knows. But it's modelled off of the standard series 3 gtr bar if it is.
the supra they get is absolutely totalled
as if you would fix it back to a new car and its n/a anyway - knobs
too jay zeeeee no shit
I shall pick up that 33 on Monday
sweet... congrats!
And yeh Mohsen, If you like the concave style but don't have the cash for TE37s, f**k the haters Rotas still look good:
Look wicked!
But... Varrstoen Wheels, by far the best TE37 copies yet, I think.
Nah I haven't mate. Front bar is fkd! LOL.
The whole car is fucked LOL!
Supra with Factor / TRD Aero = Best!
ah fair enough
cheers.
2 weeks, maybe a bit less than that. How badly do you need them? lol
just missing often more so when warming up replaced plugs first still same problem so now doing this, I'll order some tonight :P
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
