Cant decide to use pods or stock airbox, pods are louder and make noises but that could lead to more cop attention but really cant notice any difference between the 2 >_< - You can tell how bored I am being unemployed now :(
Anyone got a job for me?
airbox, cut a hole in the bottom with a tube to the front/ CAI
EDIT: what do yall think i should pay ontop of my car for an s2 r33, a very late model one too, 98
got a dude interested
Edited by Mohsen
Stock airbox is good for 300killer wasps, I see no reason to change to pods unless your making more powahh. Just another thing to be defected for if you have another intake mod
Or go highflow panel filter.
+1 Billy
Gee mohsen i wonder where u got the cai idea from....
Do I know if it would work on a gtr though? No. But pods are fine with standard fmic. Standard fmic doesn't need to be changed till big power either so why not pods? Can't get done for em
The CAI thing, Steve (forgot what his username is) have a CAI setup in his 33 GTR that attach to the airbox.
Pod filters are fine as long you have standard FMIC, both stock Airbox and FMIC is reportedly good for up to 400rwkw.
So my mechanic just went to install my new lightened flywheel... Pulled the old one out, it was a lightened one too >_< Fail.
Going down there tomorrow to look at them both and choose which one to keep. I don't want anything too weak for the button clutch that's going in.
unless its different to gtsts wouldnt that not work as air is fed from the top?
that may only apply to gtsts.
oh and what billy said!!
High flow panel filter + remove the lid. Will be as loud as a pod and if you get pulled over just put the lid back on
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
