harsh lol :laugh:
Fixed back for track days etc takes 10min to put old seat back in... I have never moved my drivers seat in 5 years of owning my car for someone to get in lol f**k that, go around!
oh fair enough but still easier to clean around if you can move it lol
yeah coz easier access to the back seat is girly/muztek...
I don't move my driver seat. Ever. Get in through the passenger side, its got a lever and slide mechanism for that.
Dunno why anyone in their right mind would put a fixed back on the passenger side. It's not like you're going rally driving and have a navigator all the time.
re; house auctions.
If you win a house auction, is it pending finance approval? Or is the winning bid locked in and you forced to pay?
I know private sale of houses can be put on hold subject to finance, but is this the same for auctions?
cheers
No, auctions are unconditional (ie you can't say "subject to...finance/building inspection etc."), you bid you buy (or come to some arrangement to cover costs and time wasted)
re; house auctions.
cheers
called the realestate agent to ask if i need a pre-approval and he said nup, just show up on the day and bid away. Didnt ask him about bid being subject to finance though, so wanted to know if anyone knew.
Wont get a pre-approval before Sunday and the auction is on then :(
yeh auction is unconditional not even cooling off period applies. pre approval doesnt mean jack for whats its worth i can put you in touch with people who can basically tell you on the phone if its ok or not for you to buy at a set price provided you give them the accurate answers to the questions they will have.
ive sold properties to ppl with pre approvals that then got declined its a bit of paper you may as well wipe your ass with.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
