did some spur of the moment fishing today with a couple mates. lost a rod/reel :/ thing went down in the water quickly...
haha was next to a BMW 4WD at traffic lights. I was on the merging lane just after the lights. Lights go green and I casually take off planning to merge infront of the 4wd. As i start crawling off the line, the 4wd launches off hitting the rev limiter and shoots off. Saw on the back that it was a BMW x5 M haha, was not expecting that to happen ~_~
4.4ltr v8 twin turbo 400kw ownage haha
aslong as you dont try and take on a porsche cayenne you'll be fine :P f**k those things fly
i got ALOT of hooks.. LOL anyone need hooks, i got hooks
anyone have a net? alvin- theres alot of small bait fish under the pier, if we had a net we could have put out some livies for the bigger fish to smash
An X5 M is no slouch either
So we ran them down the drag strip. The Cayenne did a 4.7 second 0-100km/h time on the way to a 12.9 second time for the 400m dash, while the BMW X5 M did 4.8 second 0-100km/h on the way to a 13.0 for the 400 metre dash. Call it hair-splitting, but that's how they ended up.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
