So what you're saying pat is that a stock 32 33 34 GTR would be door to door with it LOL. That ain't that blistering
haha possibly. However they probably dsg/tiptronic etc and would power through all the gears without mis-shifting or stuffing up etc
not bad for a 4wd though, considering its what over half a ton heavier? or more, and its not a sportscar
That's why I got home at 10 and slept till 4 in the afternoon haha im on the same boat rimon.. Sundays my only day off
dunno how you can be bothered lol
speaking of 4x4s been seeing heaps of range rovers around the "sport" spec one they look and sound tuff! guessing more people are watching top gear these days...
Me neither, highlight of it is all the drunk f**ks in the city clambering all over the place. There was a guy high as a f**king kite on Clarendon street trying to get into his car. f**king Lulz
those 4x4 cars are just lols, you dont buy it for a sports car, you dont buy it to go off road with, you dont buy it to save petrol, only thing its good for is surprising people like Pat :D
u mean the range Rooney?
  • Like 1
nice
my cousins mate has an x6!
beast!
you meant to say ugly beast yeh?
no, they are for getting the kids to private school
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
