So what you're saying pat is that a stock 32 33 34 GTR would be door to door with it LOL. That ain't that blistering
haha possibly. However they probably dsg/tiptronic etc and would power through all the gears without mis-shifting or stuffing up etc
not bad for a 4wd though, considering its what over half a ton heavier? or more, and its not a sportscar
That's why I got home at 10 and slept till 4 in the afternoon haha im on the same boat rimon.. Sundays my only day off
dunno how you can be bothered lol
speaking of 4x4s been seeing heaps of range rovers around the "sport" spec one they look and sound tuff! guessing more people are watching top gear these days...
Me neither, highlight of it is all the drunk f**ks in the city clambering all over the place. There was a guy high as a f**king kite on Clarendon street trying to get into his car. f**king Lulz
those 4x4 cars are just lols, you dont buy it for a sports car, you dont buy it to go off road with, you dont buy it to save petrol, only thing its good for is surprising people like Pat :D
u mean the range Rooney?
  • Like 1
nice
my cousins mate has an x6!
beast!
you meant to say ugly beast yeh?
no, they are for getting the kids to private school
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
