i said MAYBE fool (maybe means almost definately not, but there is a 1% chance)
no shit lol
jizzy come entertain us
btw- wasteland flames are really not that bad... even though i cry myself to sleep every night.. really not that bad.
anyone up my way today? need some help with something
Edited by Mohsen
Ey knob shiner I might come to this fishing thingo if I can get my parents' car. What time you expect to be back home?
im coming in my mums car too lol. fits everything
pretty much pack up when the fish stop biting. last time we went maccas or the lebo bakery on high street for brekky.. soo really up to you if you wanna leave etc
if its a nice day you see all the hotties walking around the beach etc going for jogs
who knows how to create website/register domain manage website etc etc?
i need to make a website and set it up so i can run it (fairly shit with computers) so must be simple, and what kind of budget should i allow for this?
kgo.
oh and good luck leigh :)
registering and getting the space is easy
i did mine for 120 a year on a budget hosting provider, thats for 2 years with domain name registration
paulr33.com is hosted by them and it works fine, fairly quick, reasonable set of features etc
the hosting company is juston.com
building the site isnt too hard
there are a fair few programs out there to do most of the work for you
just google some good ones then download it via torrent
Hmm my parents will probably need the car after ~11 so...
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
