I dont start fights, I FINISH THEM.
I'm the guy who gets blamed at the end of the day just cos they happen to have me on security cam swinging a barstool
what?
Then we're gonna start checking out various steak joints and rate em..
Grill Room
1 Queens Rd, Albert Park
The end :D
I'm there 10 times a year, maybe more. Never had a bad steak yet in 6-7 years and most places i regular have horrifically fked up at least 1-2 meals in that time.
It's no $15 steak & a pot place though...
I don't do steak and pot deals. Standard is around $30 minimum but we do hit the odd place with a deal (2nd meal $5 etc) and the steaks are actually decent
Outback jacks isn't too bad.
I'll put your suggestion on the list though. Any others send em my way ladies
pub steaks are shite
mind you I'm pushing the publisher at work to try and get me in on some freebies by testing for the melbourne version of this:
http://www.penguin.com.au/products/9780143205661/sydney-morning-herald-good-pub-food-guide-2011
You'll need someone to accompany you to give a more complete review. Let me know when and where. :cheers:
six to ten inches, seriously.. the end of the pier was taken and taken quite early... so i dont think we'll get to fish that on sunday morning.. and i lost my bell. Need another..
There's a technique called edging. You slowly inch closer and closer to the spot lol
Dw, well get it no matter what, NO MATTER WHAT
Stone grill eye fillet @ Paesanos Knox, don't question it, just do if you haven't already. I have these almost weekly, it's a terrible addiction. You cannot top the advantages of cooking it yourself (instantly) to perfection, having the actual meal come out in 15 minutes, and having a permanently hot meal. $30 for 250-300 gram eye fillet (varies on the day, but a good size and always good quality meat) including sauce and chips/salad. An extra $15 will get you another piece of meat (never done this, so don't know if it's the same size or not). I've been to most of the well known steak restaurants in Melbourne and the only ones that have come close IMO in terms of taste / overall quality are $50-60 for a piss small eye fillet not including sauce etc. Outback Jacks was decent but it had me wishing I hadn't ventured outside of my comfort zone.
don't speed then silly :P
this time it wasnt speeding...this time it was a nice epa notice...hate that coppa...lucky kriss didn come for that midnight cruise....waiting to hear from others if anyone else got a notice...if its just me..then ill really get pissed off...man i shud hv dun a runner while i could....he sounded nice to let us off with a warning but NO!!! had to get me done...
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
