I've got a meeting with my supervisor for a research essay i'm doing.. he emailed me yesterday saying he was available 'tommorow'.. off to a good start haha
Spoiler: that's not how you spell tomorrow
Yeah, big whoop wanna fight about it?
even still if u want to rent it out
why bother if you are just going to rent it out
buy a shitter in a place like craigeburn or something and rent that out
and rent where you want to live if you insist on living in st kilda / elwood
charge more rent for inner city joints...
True. Elwood fetches a decent price rent wise.
im not convinced good rent money = good investment idea, as with good rent comes good (ie high) repayments for the land value
i would expect the good idea behind investment would be good growth
thats why i reckon its better to buy a renter in some suburb thats cheap and likely to go up
plus its easier to afford and the land is less value
just see no purpose behind buying in stkilda/elwood ?
unless you can afford it and you have tons of spare cash
In 5-10yrs time, a property in inner city will increase more in value than your average suburbian household (this can be argued, depending if you pick an unusual growing suburb)
For example; Bendigo have plans for a new hospital, so property prices will increase due to more demand for housing for nurses, doctors etc
Gladstone (in qld) is planning to setup a major oil/gas refinery and again demands will go up.
However, a steady rapid incease in property value is always certain for inner city housing. (unless australia suffers through a gfc scenario, but then every house will be affected) and I believe you will get larger growth in the inner city than your average suburbian location in a short period of time
Huge rental demand in St.Kilda and Elwood. Stats reveal 70% of residents in both suburbs. Meaning much higher rent (due to demand)
A 1 bedroom appartment can fetch as much rent as a 3 bedroom house in the suburbs.
Alex, share your wisdom on the housing industry :P
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
