Oh there will be Stance, probably just not as flush as I was :)
oh sweet. pics when its all done yeh!
waiting on the dude that bid on my car to call back confirming if were gona meet up today.. tomorrow etc...
high stress moment like this, only 1 thing can help.
a nap
a nap
Haha and you consider that high stress?
r-comp tires puts you straight into mod class. With Bribsy, Ryan and Russel.
The hoosiers are ass in the wet as well, basically a slick. While AO50, RE55 are great in the wet (when hot), even better than street tires. Or so I've heard.
Shipping from tirerack is $350'ish for the 4. This was only a month or two ago.
I though we were in mod class anyway. Where do I find points and stuff? So I cant use r-comp tyres if I wanna get points. I just want better times haha
Shipping isnt too expensive, alot cheaper than buying from here anyway :)
Standard RWD
Standard AWD
Mod RWD
Mod AWD
Associated Over 3L (not S chassis or R chassis cars)
Associated Under 2L (not S chassis or R chassis cars)
Standard Class: (List of Free Mods allowed in standard class) Suspension - All Brakes - All Electronics (ECU, Boost Controllers) - All Intercoolers - All Pods Wheels Sizes Modified Classes: (Any of these Mods will put you into modified class) - R Spec Tyres / Slicks under a UTQG rating of 100 tread wear (not including 100) - A Roll Cage - A stripped interior. Removal of rear seats only is allowed. - Any other major weight reduction such as fibreglass doors or perspects windows - Fuel Systems - Any two out of the following four modifications to either: 1.Injectors, 2.Fuel Pump, 3.Non Nissan OEM Turbo's, or 4.A fuel pressure modification will put you into modified class. (I.E - Only one fuel system mod is allowed) - Non OEM Engine Capacities (GTST with RB26, RB30; GTR with 2.8L, etc) - Driving a "supercar" (eg. Lamborghini, Ferrari, R35GTR, Porsche 911 Turbo, GT3, GT2, Veyron etc) Standard Turbo Clarification (RWD Standard Class) RWD Standard can run any Nissan OEM turbo from any RB Skyline. Highflowing of any of these RB OEM Nissan turbo's is allowed. (GTR Standard Class) Any of these turbo's are considered a standard spec replacement turbo and are not considered a turbo mod. R32, R33, R34 N1's, HKS GT-SS's, Garrett GT2860r-7.
Marty, Jonny, you and I are in Standard RWD. It is basically an imposed power and grip limit (with the limited fuel system mods and tires)
I'll be in standard 4WD then :D I'll probably suck being the first time on Winton in a turbo car, hell the first time I've even taken the R to the track. Was good fun in my old N/A though. What sorts of speeds do you hit down the straight? Cant remember
So your cheating by using a hi-flowed turbo? ;) haha
So I take it i'm last?
It doesnt really bother me what class I get put in, I just want faster times....
I would rather the stocker, its got mad response. But blows its ass out after time.
You're not last either, Rob in the other black S2 is keeping the bottom warm at the moment.
Winton is 170kmh tops for me, but it is not sustained. Ie you're on the gas out of turn 15, then into fourth 100m down the road, then hard on the brakes 450m later.
Where as Calder, PI and Sandown you are on the gas for a good time. Though this all depends on how you exit the corner onto the straight.
they yours?
nah they new
Hmmm I cant afford them atm, id rather buy rota's in any size I want, if they break who cares LOL
sorry man, they are 18x9.5+28 (i got told the wrong info)
also driftek's are now available in 17/18 x 9.5 in any offset you want from 0-25
in other news, work hadn't even STARTED my XD9's that i ordered 3 months ago, so i swapped the order for these:
fronts are 17x9+12 rears are 18x9.5+12
some folks gon love em, some gon hate em
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
