Nope.
Garrett -9s, much better turbo than N1.
Leigh since you mentioned you're un-rego it, go T04Z.
Specs are similar but -9's can out put an extra 60PS over the R34 GTR N1's.
Probably get more top end.
And response on GT-SS is much nicer than 34 N1.
The specs seem similar, but how so, GT-SS are better in response?
Is there refinement in the development of the GT-SS on top of the R34 GTR N1's?
GT-SS is basically modern version of -7 thus -9 is nicer turbo if the GTR is daily driven.
Different compressor wheel between -7 and -9, have a read on -7/-9/-5 thread on FI.
Pretty sure we've discussed about this before!
Yeah right, I see.
I will have to have a thorougher look through my updated turbo chart.
:laugh: I remember.
Wallet feels ok, was expected to be a few things wrong doing the 100k service had to get new rear rotors / pads so decided may as well get a bit of a upgrade for the track / good pads the rear rotors look sexy now but the fronts still stock for now :P
You'd have to be the first person to upgrade their rear brakes before their fronts...
Do you have bicycle lock/chain/whatever?
Had literally bought a brand new massive cable code lock that morning AND had a wire with a padlock on. They didn't have d-locks which would have been better.
Charlie, see if you can check the Cities CCTV Security Cameras.
May be able to identify who took your bike.
Already on it. The CCTV are all targeted at entrances so no clear view of the bike rack it was on but may see it going past.
Ironically I work for an insurance company and I'm not covered. I thought about changing my cover but really did not expect it to be stolen on the first day EVER that I lock a pushy up.
What about the rears? Get away with just a roll and 0 camber?
in what size? he mentioned 2
Geez, I'd better off buying another R.
because you have some second hand wheels that you can easily sell for another set in the correct offset?
makes no sense man
They aren't light this f**kers. Would have been a bitch of a job if you don't use a hoist
this... i'd hate to do it without a hoist....
Nice! Hows the wallet feel?
after a visit to racepace your wallet feels like a $2 hooker that got stuck on a navy ship for 3 months
almost.... brisby did the last DECA of last year with bigger brakes on the rear than front... provided lulz
makes no sense man
You're forgetting I'm insane.
Once again I suppose I could sell them or just leave it in garage...
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
